Jul 17th, 2024, 11:34pm
could damping factor >>1 (Read 3145 times)
supermoment
Jul 29th, 2010, 10:35pm
For a over-damped pll system, the zeta (damping factor) must be >> 1.
I checked the damping factor formula (Cartesian plane), it shows zeta=wn*cos(theta)/wn = cos(theta), which is bounded by +1,-1 from mathematics aspect.
could zeta/damping factor >>1?
raja.cedt
Re: could damping factor >>1
Reply #1 - Jul 30th, 2010, 10:51pm
hello,
when you are saying damping factor is cos function you are assuming that pole are on complex plane, so damping factor is between 0 to 1. If pole are on the real axis then damping factor will be more than one. So your cos formula don't catch this one.
Assume you have poles at A+JB and A-jB so total equation is S^2+2AS+A^2+B^2, so damping factor is A/(sqrt(a^2+B^2)..so geta is cos function.
when they are on the real axis this equation is not correct.
Hope you got the point.
Rajasekhar.
supermoment
Reply #2 - Jul 30th, 2010, 10:57pm
yup, it is same as what I assumed.
So the cos(theta) formula is only applicable until critical damped pll when zeta=1.
any other comments?
raja.cedt
Reply #3 - Jul 31st, 2010, 1:17am
yes...or you can say if poles are in complex plane only
