Aug 5th, 2024, 3:18pm
Mimcap mismatch in 65nm TSMC (Read 145 times)
carlgrace
Berkeley, CA
Aug 06th, 2010, 1:48pm
I'm simulating some matched MIMCAP capacitors using eldo in TSMC 65nm.  I'm getting some variation using monte carlo, but not as much as I would expect.  Namely, I would expect the caps (based on their sizes) to match to about 0.1%, but the settling value in the switched-cap amplifier I'm simulation is within more like 0.01%.  Am I doing something wrong?  I'm setting mismatchflag=1 and it looks like I'm getting *some* mismatch, just not as much as I supposed.
Carl
Re: Mimcap mismatch in 65nm TSMC
Reply #1 - Aug 7th, 2010, 3:00am
I can't find out any design issue in your post.
carlgrace wrote on Aug 6th, 2010, 1:48pm:
Confirm std-deviation of MIMCAP as a result of  MonteCarlo Trials.
Lex
Eindhoven, Holland
Reply #2 - Aug 12th, 2010, 1:41am
Can you isolate the problem by only adding mismatch on capacitors and then verify the result? Maybe you can play with the simulators tolerances, to ascertain you're not looking at numerical noise. 0.01% is quite small to be honest.
carlgrace
Berkeley, CA
Reply #3 - Aug 17th, 2010, 6:42pm
Turns out installing an updated version of the kit fixed the problem.  Weird.
Thanks for the replies.
Carl
Reply #4 - Aug 26th, 2010, 5:10pm
carlgrace wrote on Aug 17th, 2010, 6:42pm:
Carl
Weird? Nope, just bad models.
Not to be surprised.
