Jul 17th, 2024, 11:30pm
pss convergent issue in osc phase model. (Read 2597 times)
supermoment
Aug 08th, 2010, 3:13am
I simulated the osc phase model but fail to run pss & pnoise.
"Analysis `pss' terminated prematurely due to error."
It is due to convergent issue in pss run.
The input node is connected a voltage source vdc or idc with a ideal res.
`include "disciplines.vams"
	  discipline phase
		    potential Angle;
	  enddiscipline
`include "constants.vams"
module phasemodel_osc(in, out);
	  input  in;
	  output out;
	  phase  out;
	  voltage in;
	  parameter real gain = 1 from (0:inf);  //Transfer gain, Kvco (Hz/V)
	  parameter real n=0 from [0:inf);   //white output phase noise at 1Hz (rad^2/Hz)
	  parameter real fc=0 from [0:inf);  //flicker noise conrer freq (Hz)
	  analog begin
		    Theta(out) <+2*`M_PI*gain*idt(V(in));
		    Theta(out) <+ flicker_noise(n, 2, "wpn") + flicker_noise(n*fc, 3, "fpn");
supermoment
Re: pss convergent issue in osc phase model.
Reply #1 - Aug 8th, 2010, 6:06am
I am a novice on RF analysis.
I want to study the phase noise of each components in the whole PLL. I know CPPsim can make it easily.
I just test out the osc alone. Since the input is a voltage, i set a voltage in the input. The reason to use pss is to observe the pnoise, which require pss run.
Reply #2 - Aug 8th, 2010, 6:43am
supermoment wrote on Aug 8th, 2010, 6:06am:
You can't understand concept of "Phase Domain Model" at all.
supermoment wrote on Aug 8th, 2010, 3:13am:
Show me your netlist.
In your netlist, what is large signal ?
"Phase Domain Model" is not autonomous circuit.
Again see http://www.designers-guide.org/Forum/YaBB.pl?num=1280215169/7#7
Also see http://edocs.soco.agilent.com/display/ads2009/Phase+Noise+Simulations+using+Smal...
Here conventional small signal AC(Noise) Analyses are used.
« Last Edit: Aug 8th, 2010, 8:06am by pancho_hideboo »
Reply #3 - Aug 8th, 2010, 10:24am
You are simulating a phase-domain model of the oscillator alone? Not in a feedback loop? And you are doing it with PSS? That won't work. The phase-domain model of an oscillator is an integrator, which does not have a periodic solution.
You don't need PSS when you are simulating a phase-domain model, a simple noise analysis will do because the signals themselves are formulated in terms of phase, any noise you see on a phase signal with naturally be phase noise.
supermoment
Reply #4 - Aug 8th, 2010, 10:56pm
Thank you.
I eventually have made it by putting everything together. It could be analyzed in noise analysis and pnoise analysis (same result as in noise analysis)
The problem previously i got is that I did not have phase noise source :p
Again, thanks for your patience.
the next thing is to extract transistor level behavior from PSS & Pnoise run.
