Jul 18th, 2024, 3:37am
How to simulating multiple netlists in a single ocean script (Read 6604 times)
pkd
India
Aug 11th, 2010, 4:15pm
I want to systematically add few stuff to my circuit and then obtain the result from it by running a single ocean script. In my case I want to add two more inverter in each subsequent netlist to study the effect of tapping from delayed stages. But when I run the simulation by adding multiple design() statements, I don't see ant change in results. Perhaps even though it's running, but it's not able to change the netlist which it simulates multiple times in a single ocean script. When I print the variable which is passed as the name of the design netlist file, it prints  properly, but while it simulates in a single script, it doesn't seem to be simulating the changed netlists in each run.
Please suggest me a way to achieve the required goal ie simulate multiple netlists in a single ocean script. as soon as possible.
Here is the part of the code I had written to try simulating multiple netlists in the main ocean script file.
design_file_list='( "~/simulation/fight_model_variable_fb_delayy/spectre/schematic/netlist/netlist_2
fb_inv" "~/simulation/fight_model_variable_fb_delayy/spectre/schematic/netlist/netlist_4
fb_inv" "~/simulation/fight_model_variable_fb_delayy/spectre/schematic/netlist/netlist_6
fb_inv" "~/simulation/fight_model_variable_fb_delayy/spectre/schematic/netlist/netlist_8
fb_inv")
foreach(design_file design_file_list
design(design_file)
analysis('tran ?stop "30n"  ?errpreset "conservative"  ?step "1p"
           ?maxstep "5p"  )
run()
rfcooltools.com
Re: How to simulating multiple netlists in a single ocean script
Reply #1 - Aug 12th, 2010, 2:15pm
by calling the function
simulator('spectre)
this will flush the resident netlist out of the memory so you can load a new one.
You will have to set the results directory and modelfiles again
http://rfcooltools.com
pkd
India
Reply #2 - Aug 12th, 2010, 6:18pm
Quote:
Posted by: rfcooltools.com      Posted on: Today at 2:15pm
simulator('spectre)
I already did that. Still it doesn't work.  :-[
pkd
India
Reply #3 - Aug 13th, 2010, 6:44am
Specify the different directory for each run() where the PSF files are stored by inserting resultsDir( "/aho/boke/kasu/nasu" ) before run().
What do you mean by "different directory" ? I see only one option for specifying the results directory using resultsDir() function. Is there anything else? I am already putting resultsDir() function in each loop, hence it should get refresh each time. But unfortunately I get the same results for each run. Probably it's not changing the netlist it's simulating.
Reply #4 - Aug 13th, 2010, 6:56am
pkd wrote on Aug 11th, 2010, 4:15pm:
design_file_list='(
fb_inv"
fb_inv"
fb_inv"
fb_inv"
design(design_file)
           ?maxstep "5p"  )
run()
pkd wrote on Aug 13th, 2010, 6:44am:
There is no "resultDir()" in your code.
Show me true code which you use actually without any modification.
pkd
India
Reply #5 - Aug 15th, 2010, 9:42pm
Here is my actual code...
ocnWaveformTool( 'awd )
out = outfile("/home/pkd/ocean_script/fine_delay_vs_tap_pt.txt" "w")
close( out )
design_file_list='( "/home/pkd/simulation/fight_model_variable_fb_delayy/spectre/schematic/netlist/netlist_0fb_inv" "/home/pkd/simulation/fight_model_variable_fb_delayy/spectre/schematic/netlist/netlist_2fb_inv" "/home/pkd/simulation/fight_model_variable_fb_delayy/spectre/schematic/netlist/netlist_4fb_inv" "/home/pkd/simulation/fight_model_variable_fb_delayy/spectre/schematic/netlist/netlist_6fb_inv" "/home/pkd/simulation/fight_model_variable_fb_delayy/spectre/schematic/netlist/netlist_8fb_inv")
corners='( "ss" "tt" "ff" "snfp" "fnsp")
extn="_dir"
foreach(corner corners
		dsn=sprintf( nil "%s%s" design_file,extn)
		net=sprintf( nil "%s%s/netlist" design_file,extn)
		simulator( 'spectre )
		design(	design_file )
  modelFile( list( "/home/pkd/cadence/foundry_data/umc13mmrf/../Models/Spectre/L130E_HS12_V241.lib.scs" sprintf( nil "%s" corner)) )
out = outfile("/home/pkd/ocean_script/fine_delay_vs_tap_pt.txt" "a")
fprintf(out "\n\n%s Corner\n\n   Tapping after zero delay\n" corner)
fprintf(out "\n%s\n" design_file)
close( out )
temp( 27 )
res=1e3
wf=1e-6
wr=5e-7
desVar(	  "res" res )
desVar(	  "wf" wf	)
desVar(	  "wr" wr	)
		?maxstep "5p"  )
resultsDir( "/home/pkd/simulation/fight_model_variable_fb_delayy/spectre/schematic" )
run()
selectResult( 'tran )
int_delay=delay(VT("/in_fine"),0.6,3,"rising",VT("/n1"),0.6,3,"rising")*1e12
ip_op_delay=delay(VT("/in_fine"),0.6,3,"rising",VT("/out_fine"),0.6,3,"rising")*1e12
test_delay=delay(VT("/in_fine"),0.6,3,"rising",VT("/nfb"),0.6,3,"falling")*1e12
wf=wf*1e9
wr=wr*1e9
fprintf(out "	     %4.0f  %4.0f  %4.0f  %4.1f  %4.1f  %4.1f \n" wf,wr,res,int_delay,ip_op_delay,test_delay)
fprintf(out "	     %4.0f  %4.0f  %4.0f \n" wf,wr,res)
close( out )
;;plot(getData("/n1") getData("/in_fine") )
Reply #6 - Aug 15th, 2010, 11:20pm
Try the following code. Quote:
base_dir = "/home/pkd/simulation/fight_model_variable_fb_delayy/spectre/"
design_file_list = '(
    "netlist_0fb_inv", "netlist_2fb_inv", "netlist_4fb_inv", "netlist_6fb_inv", "netlist_8fb_inv"
temp( 27 )
res=1e3
wf=1e-6
wr=5e-7
desVar(        "res" res )
desVar(        "wf" wf      )
desVar(        "wr" wr      )
           ?maxstep "5p"  )
extn="_dir"
foreach(corner, corners
     foreach(design_file, design_file_list
           design( strcat(base_dir, "schematic/netlist/", design_file) )
close( out )
proj_dir = strcat( base_dir, design_file, "_", corner )
resultsDir( proj_dir )
run()
openResults( strcat(proj_dir, "/psf") )
1e12
wf=wf*1e9
wr=wr*1e9
close( out )
Or delete "input.scs" before each run by using "system()".
