Jul 17th, 2024, 11:18pm
Zener Diode Model in HSpice (Read 4466 times)
linker
Aug 15th, 2010, 11:42pm
Anyone can help me with a Zener Diode model in HSpice?
Thanks!
linker
Re: Zener Diode Model in HSpice
Reply #1 - Aug 16th, 2010, 4:03am
linker
Reply #2 - Aug 16th, 2010, 11:38pm
MODEL DZ   IS=80.21637E-9  N=2.80334  RS=3.412605e-002  CJO=135E-12  M=.5033  VJ=.75
+ ISR=4.2604E-6  NR=4.11012  BV=6.2   IBV=49.004E-3  TT=150.49E-9
COMMENTS:please notice to this comments
ISR  IS   the minimum current of  zener diode
IBV  is   the  maximum current  of  the  zener diode
BV  Is   the  break  voltage of  zener diode
Reply #3 - Aug 17th, 2010, 4:51am
linker wrote on Aug 15th, 2010, 11:42pm:
What help do you need?
BTW:
ISR  is  the reverse saturation current (at TNOM)
IBV  is  current at V = -BV
BV  is the breakdown voltage
Note that one can have funny issues when computing I at V=-BV from
 I(v) = IS * (exp(v/(N*vt)) -1) + ISR * (exp((v+BV)/(NR*vt)) - 1) + GMIN * v
and comparing that to IBV.  Of course, I(v) should be continuous, so it seems to me that IBV is overconstraining the system, and maybe is just approximate.
