Aug 17th, 2024, 1:37am
Monte Carlo/TSMC (Read 2166 times)
memomemomemo
Monte Carlo/TSMC
Aug 18th, 2010, 2:38am
Hi!
I am doing Monte Carlo simulation ( 90nm TSMC Process) with cadence5. I can see the process variation for mos transistors however not the mismatch.
How can I find out what is wrong? Should I enable or add a model library?
Thanks!
Mehmet
mydreamhouse
Re: Monte Carlo/TSMC
Reply #1 - Aug 22nd, 2010, 5:13am
before run monte carlo simulation,   you should do:
(1)use mismatch symbol in PDK
(2)use mc_ section in library
View Profile mydreamhouse   IP Logged
