Aug 16th, 2024, 4:10pm
Verilog A ladder (Read 514 times)
Streamcx
Verilog A ladder
Aug 20th, 2010, 10:20pm
I`m starting with Verilog A.
I need "ladder" from 0V to -2.04V with step 0.008 V (step can be smaller), 256 time intervaks.
I have this code (not my):
`include "disciplines.vams"
module ladder (outp,outm);
output outp,outm;
electrical outp,outm;
// extent of the signal output
parameter real vmin=0;
parameter real vmax=2.56;
// number of steps in the "ladder"
parameter integer maxcount=256;
// is it periodic? Set to 0 if you want it to be one shot
parameter integer periodic=1;
// period of time between steps in the ladder
parameter real period=10n;
// rise, fall, and delay of each step
parameter real tr=0.1n;
parameter real tf=0.1n;
parameter real td=0;
// internal variables
real scale;
integer count;
analog begin
    @(initial_step) begin
	count=0;
	scale=(vmax-vmin)/(maxcount-1);
    @(timer(period,period))
	if(periodic) count=(count+1)%maxcount;
	else count=min(count+1,maxcount-1);
    V(outp,outm) <+ transition(count*scale,td,tr,tf);
I set Vmax=0, Vmin=-2.048. Why when time increase signal go down from 0, to -2.048 (like I need).
Why this is not go up from 0 to 2.048?
Re: Verilog A ladder
Reply #1 - Aug 21st, 2010, 12:30am
At first glance, the code looks okay. Any chance you simply wired the component into the circuit backward by accidentally flipping the terminals?
