Aug 15th, 2024, 10:31am
Ill Convergence of PSS when Hysteresis Buffer is included (Read 11497 times)
Aug 25th, 2010, 9:10am
When target circuit include Hysteresis Buffer such as Schmitt Trigger Buffer,
it is very difficult to get convergence of periodical steady state analysis based on HB or Shooting-Newton approaches.
This issue is not concerned with specific vendor's simulator engine.
Is there anyone who have same experience ?
How do you overcome this issue ?
RFICDUDE
Re: Ill Convergence of PSS when Hysteresis Buffer is included
Reply #1 - Aug 26th, 2010, 4:45pm
Hi Pancho,
I suspect, although I do not know for sure, that hysteresis is a form of the dreaded "hidden state" problem that plagues steady-state simulators. It would seem to be true that hysteresis certainly depends on a past value of a state-variable. If this is true, then it may be the case that this problem cannot be solved even with transient assistance (again I really don't know for sure).
I would hope that Ken Kundert could provide some insight here?
The Dude
Reply #2 - Aug 27th, 2010, 8:29am
RFICDUDE wrote on Aug 26th, 2010, 4:45pm:
I don't think so.
If we realize "Hysteresis" by Verilog-A, we will encounter "hidden state" problem.
But my circuits are real transistor level circuits, so there is no "hidden state" problem.
If we use "@cross()" to describe "Hysteresis" in Verilog-A, such module can't work in PSS analysis based on HB approach,
although it can work in PSS analysis based on Shooting-Newton approach.
It is true for real transistor level circuits.
"Charges of Capacitor" are "State-Variables".
vp1953
Reply #3 - Aug 27th, 2010, 4:20pm
Hi Pancho,
Does increasing the number of harmonics (substantially) make any difference? I am thinking something like a schmitt trigger with abrupt output transition edges (almost like a square wave) may need much more harmonics to adequately cover the spectrum
Reply #4 - Aug 27th, 2010, 10:29pm
See http://www.designers-guide.org/Forum/YaBB.pl?num=1237890768/10#10
vp1953 wrote on Aug 27th, 2010, 4:20pm:
I usually use 31 as Harmonics in HB.
I also tried 101 Harmonics in HB. But convegence can't be improved or succeeded.
Harmonics of 31 is generally enough for master large signal analysis, although it can not be enough for slave small signal analysis.
I think ill-convergence is due to a deadzone of Hysteresis Buffer.
There could be an oscillative behavior if an input signal is small around a deadzone.
pancho_hideboo wrote on Aug 25th, 2010, 9:10am:
Again see start descriptions of this thread.
I tried following engines.
 - HB with Frequecy Domain Preconditioner in Agilent GoldenGate
 - HB with Time Domain Preconditioner in Agilent GoldenGate
 - TB(Time-Balance) in Agilent GoldenGate
 - TS(Time-Shooting) in Agilent GoldenGate
 - TB Assisted HB in Agilent GoldenGate
 - TS Assisted HB in Agilent GoldenGate
 - Transient Assisted HB with Frequecy Domain Preconditioner in Agilent GoldenGate
 - Transient Assisted HB with Time Domain Preconditioner in Agilent GoldenGate
 - PSS based on HB in Cadence Spectre
 - PSS based on Shooting-Newton in Cadence Spectre
« Last Edit: Aug 28th, 2010, 9:27am by pancho_hideboo »
vp1953
Reply #5 - Aug 30th, 2010, 3:28pm
Hi Pancho,
Just thinking out loud, maybe you have already tried this. In PSS with Cadence Spectre (with either of the methods), setting the beat frequency (using manual adjustment) to something that is substantially lower than the frequency of the input signal and at the same time setting the number of harmonics so that it covers 31x of the input signal frequency.
RFICDUDE
Reply #6 - Aug 31st, 2010, 2:57am
Are you simulating just the trigger circuit by itself (i.e. are there other circuits also driven by the periodic source)?
Is the circuit behavioral or transistor level?
I only ask because I could play around with a behavioral circuit to see the circuit can be tricked into converging by adding a similar driven circuit without hysteresis included.
It is doubtful that my idea will work, but it is something to try.
I think (again I don't know for sure) that the hysteresis creates an ill condition for determining the periodicity of the solution because it perturbs the zero crossings when it makes a decision. You may have to think of ways (tricks) to make the output of the circuit periodic on average (I am not sure if this can easily be done).
Reply #7 - Aug 31st, 2010, 4:37am
vp1953 wrote on Aug 30th, 2010, 3:28pm:
It's never appropriate and never practical and never helpful, if we consider a common divisor frequency between input signal and oscillative signal.
If I dare to try alternative analyses, appropriate candidates are :
 - Autonomous Multitone Steady State Analysis such as Autonomous Multitone HB(Autonomous-QPSS)
 - One Driven Tone Envelope Analysis
There is no "beat" in analysis statement for PSS of Cadence Spectre.
Don't use a term of "beat", if you mean PSS of Cadence Spectre.
See "spectre -h pss", "beat frequency" of PSS setting UI is not beat frequency.
It is a "fundamental frequency" not beat frequency.
See http://www.designers-guide.org/Forum/YaBB.pl?num=1268969030/7#7
RFICDUDE wrote on Aug 31st, 2010, 2:57am:
Hysteresis buffer is no more than one small part of circuits in my simulation.
Full transistor level.
pancho_hideboo wrote on Aug 27th, 2010, 8:29am:
I don't think so.
If I remove or make disable Hysteresis buffer, simulation can converge without any difficulty.
« Last Edit: Aug 31st, 2010, 5:59am by pancho_hideboo »
Reply #8 - Sep 1st, 2010, 5:43am
There is nothing about hysteresis that in inherently problematic for PSS analysis. I suspect that there is something else that is causing the problem. If you simulate the circuit in Spectre, try using transient analysis with strobing and set the strobe period equal to the period of the expected fundamental tone. Then examine all the strobed signals and make sure they all appear to become constant valued. If they do not then your circuit does not have a periodic solution with that period. Check the supply currents first, they are most likely to show the problem.
Reply #9 - Sep 1st, 2010, 6:00am
Ken Kundert wrote on Sep 1st, 2010, 5:43am:
I don't think so.
pancho_hideboo wrote on Aug 27th, 2010, 10:29pm:
There is no problem in supply currents in my test case which include hysteresis buffer.
An oscillation could occur between Vdd and Drain of MOSFETs.
See the following case, although it is not hysteresis buffer.
http://www.designers-guide.org/Forum/YaBB.pl?num=1221012939
Even if I can observe oscillation in supply current for Transient Analysis,
driven HB Analysis can be converged without any difficulty in the above case which does not include any hysteresis buffer.
Also see the followings.
http://www.designers-guide.org/Forum/YaBB.pl?num=1243078889
http://www.designers-guide.org/Forum/YaBB.pl?num=1234428781/7#7
But ideal voltage source having zero impedance is used in my test case which include hysteresis buffer.
So there is no oscillation between Vdd and Drain of MOSFETs.
And convergence can be improved if I loose accuracy setting, for example from moderate to liberal in Shooting-Newton PSS of Cadence Spectre.
Reply #10 - Sep 3rd, 2010, 6:45pm
Again, there is nothing about hysteresis itself that is inherently problematic, as long as you generate a good starting point, which would be done naturally if you use an initial transient interval. That does not mean that there is something else about your hysteretic buffer that is causing the problem. I don't know what you mean by a dead zone, but I cannot see why a deadzone in general would be problematic. If the buffer were unstable, then that would be problematic because it would result in a non-periodic solution. That is why I recommended the strobing. With strobing you will be able to easily see if your circuit has a periodic solution for the period you chose.
