purplewolf wrote on Aug 25th, 2010, 8:13pm:My Power Amplifier citcuit has a TLine from analoglib
and I want to run PSS to calculate PAE,Pout ,comrepssion..
but pss does not runs with tlines..
is there any alternative accurate way to do it..
I don't know what you mean by "
analoglib/TLine" and also I don't know what simulator you use.
I assume "
analogLib/tline" on Cadence DFII.
We can use "analogLib/tline" of Cadence in PSS analysis of Agilent ADSsim and GoldenGate without any problem.
http://edocs.soco.agilent.com/display/ads2009/tlineWhat simulator engine you use is Cadence Spectre ?
Still can't we use "analogLib/tline" in PSS analysis of Cadence Spectre ?
Did you try HB engine of Cadence Spectre with tstab=0 ?
If it is not helpful, use "analogLib/mtline" instead of "analogLib/tline", although I have not used them.
http://www.designers-guide.org/Forum/YaBB.pl?num=1169142108The followings are general notes for you.
Always describe correct tool's name and vendor's name which you use as tool or simulator.- Don't do multiple posts which are same content.
- Don't request source code or behavioral model without any efforts.
There are many simulators which have analyses called as PSS, PAC and Pnoise.- Describe in detail with using correct terminologies.
- Warnigns are different from Errors.
- ADS is not name of simulator.
- There is no tool which name is Cadence.
- Don't use Direct Plot of Cadence ADE blindly without knowing definition.
- All gains in Direct Plot of Cadence ADE are "right", "true" and "practical" voltage gain.
- Don't mix up Simulation with Post Processing. They are completely different phase.
- MATLAB are different from Simulink.
- Learn measurements using actual instruments. Not "EDA Tool Play
