Jul 16th, 2024, 10:01am
PSS with TLINE in circuit (Read 9404 times)
purplewolf
Aug 25th, 2010, 8:13pm
My Power Amplifier citcuit has a TLine from analoglib and I want to run PSS to calculate PAE,Pout ,comrepssion..but pss does not runs with tlines..is there any alternative accurate way to do it..
Re: PSS with TLINE in circuit
Reply #1 - Aug 26th, 2010, 6:09am
purplewolf wrote on Aug 25th, 2010, 8:13pm:
I don't know what you mean by "analoglib/TLine" and also I don't know what simulator you use.
I assume "analogLib/tline" on Cadence DFII.
We can use "analogLib/tline" of Cadence in PSS analysis of Agilent ADSsim and GoldenGate without any problem.
http://edocs.soco.agilent.com/display/ads2009/tline
What simulator engine you use is Cadence Spectre ?
Still can't we use "analogLib/tline" in PSS analysis of Cadence Spectre ?
Did you try HB engine of Cadence Spectre with tstab=0 ?
If it is not helpful, use "analogLib/mtline" instead of "analogLib/tline", although I have not used them.
http://www.designers-guide.org/Forum/YaBB.pl?num=1169142108
The followings are general notes for you.
- Always describe correct tool's name and vendor's name which you use as tool or simulator.
- Don't do multiple posts which are same content.
- Don't request source code or behavioral model without any efforts.
- There are many simulators which have analyses called as PSS, PAC and Pnoise.
- Describe in detail with using correct terminologies.
- Warnigns are different from Errors.
- ADS is not name of simulator.
- There is no tool which name is Cadence.
- Don't use Direct Plot of Cadence ADE blindly without knowing definition.
- All gains in Direct Plot of Cadence ADE are "right", "true" and "practical" voltage gain.
- Don't mix up Simulation with Post Processing. They are completely different phase.
- MATLAB are different from Simulink.
- Learn measurements using actual instruments. Not "EDA Tool Play
purplewolf
Reply #2 - Aug 30th, 2010, 8:25am
it doesnt work with tstab = 0 with both  HBengines in Cadence Spectre..
ill go for Golden gate
thanx!!!
Reply #3 - Aug 30th, 2010, 8:42am
purplewolf wrote on Aug 30th, 2010, 8:25am:
Did you try to use "analogLib/mtline" instead of "analogLib/tline" ?
If you use Agilent GoldenGate, you can use more good line model than "analogLib/tline" or "analogLib/mtline".
See http://www.designers-guide.org/Forum/YaBB.pl?num=1272383469
If you use Agilent GoldenGate, use Agilent GoldenGate version 4.4.X.
See http://www.designers-guide.org/Forum/YaBB.pl?num=1268404959/7#7
purplewolf
Reply #4 - Aug 30th, 2010, 2:35pm
pancho_hideboo wrote on Aug 30th, 2010, 8:42am:
I used tline... i have to figure out how to use mtline ...
Tawna Wilsey
Snohomish, WA
Reply #5 - Sep 8th, 2010, 11:28pm
Hi Purple Wolf,
Do not use tline from analogLib.  Use mtline instead.  There is an application note on how to use mtline on Cadence Online Support:  support.cadence.com (I wrote the appNote a couple of years ago).
With mtline, I recommend the field solver type of input option.  My second preference would be to use the RLGC type of input option.  I do not recommend using the tline option (It's older technology, kept around for legacy reasons.)   The appNote goes into detail about each of the different options.
For example:  If you want to include dielectric loss in your transmission line, I recommend using the Field Solver with the sublossline transmission line type and the wideband model type.
You should also use the harmonic balance engine in Spectre.  Additionally, I strongly recommend using the latest MMSIM 7.2 ISR.
In more recent versions of IC (5.1.41 USR6, 6.1.4), you will also have a cross sectional viewer, which makes using the Field solver option very easy to use.
Again, let me emphasize...do not use tline.  The parameters used are from older modeling technology and have inherent limitations.
Finally, if you are having any issues with convergence or accuracy, I strongly recommend contacting Cadence Customer Support.  Customers have been using mtline with spectreRF for many years without problems.
Best regards,
Tawna Wilsey
Cadence Design Systems
tawna@cadence.com
Tawna Wilsey
View Profile tawnaWilsey   IP Logged
purplewolf
Reply #6 - Sep 9th, 2010, 2:58am
ok thanks...
ive got the app note..
