Jul 16th, 2024, 11:13pm
PSS+PNOISE for limiting amplifier jitter (Read 6768 times)
Pete
Canada
Aug 26th, 2010, 10:39am
I am using PSS+PNOISE to estimate output jitter of a limiting amplifier as follows:-
1) Drive the input with a single tone at Fin
2) Run PSS with shooting method, beat frequency Fin, select number of output harmonics N such that Fin*N > circuit's 0dB gain
3) Run PNOISE with noisetype=jitter, maximum sideband=N, reference sideband=0, frequency sweep from 1Hz to Fin/2
4) Plot Jee with integration limits 1Hz to Fin/2
So far I have been happy with this procedure - the results for Jee etc are reasonable and agree with a few TRAN+NOISE sims run as spot checks. It also agrees with recommendations elsewhere on the forum (e.g. www.designers-guide.org/Forum/YaBB.pl?num=1092399689) and my somewhat incomplete understanding of exactly how the simulator works its magic.
Recently, other members of my design group have questioned this approach. What they propose is mostly similar, but change PNOISE as follows:-
3a) Run PNOISE with noisetype=jitter, Sideband array of indices, additional indices=0, reference sideband=0, frequency sweep from 1Hz to 'very high' (well beyond circuit 0dB gain)
4a) Plot Jee with integration limits 1Hz to 'very high' (same as above)
Jitter numbers for both methods are very close (less than 1% mismatch, although not identical). However, when I run a few stripped-down test cases the actual output noise (using noisetype=sources) shows bigger deltas, up to 10% or so for the particular examples I have run so far.
My questions are therefore:-
a) Which of these methods is 'correct'?
(Maybe they are equivalent? Maybe they are both wrong?)
b) Can someone explain (or recommend a good reference to explain) the difference, if any, so I can improve my understanding?
Many thanks!
Pete
vp1953
Re: PSS+PNOISE for limiting amplifier jitter
Reply #1 - Aug 26th, 2010, 4:30pm
Hi Pete,
Using the second approach (i.e. the one suggested by your design group), but with one change namely that the number of output harmonics for PSS is increased significantly, does that make any change in the results?
Pete
Canada
Reply #2 - Aug 26th, 2010, 4:44pm
Hi vp1953,
Yes. Using the second method with more than a single harmonic and noise integration bandwidth > Fin/2 results in significantly higher jitter reported by PNOISE.
As I understand it, this is due to aliasing.
(Note: This was the result that sparked the debate. Several designers used the original method, but with integration bandwidth >> Fin/2 and got the "wrong" result. Therefore the suggestion was to use a single harmonic. I prefer the original method, but am hard pressed to explain why to myself, let alone others...)
Pete
vp1953
Reply #3 - Aug 26th, 2010, 5:14pm
Method 1 and Method 2 gives similar results for PSS+Pnoise. But TRAN+Noise gives different results - what was the difference in settings for TRAN+Noise simulation?
Pete
Canada
Reply #4 - Aug 26th, 2010, 6:24pm
Actually TRAN+NOISE matches quite well too (I run for a few hundred cycles, export the zero crossings into a spreadsheet and calculate Jee by curve fitting a Gaussian CDF). I get an answer within about 5% of PSS+PNOISE (either of the methods in my original post).
Pete
Frank Wiedmann
Munich, Germany
Reply #5 - Aug 27th, 2010, 2:19am
I could imagine that the two methods are only equivalent if there is no significant frequency translation of noise in the circuit (as happens for example in mixers). I have not tried your second method so far and I am a little suprised about how well your results match.
Unlike for noisetype=jitter (when using the first method), for noisetype=sources you always have to integrate up to 'very high' frequencies.
Have you already looked at http://www.designers-guide.org/Analysis/sc-filters.pdf ?
Pete
Canada
Reply #6 - Aug 27th, 2010, 8:02am
Hi Frank,
Thanks for the advice - I have looked at sc-filters.pdf and believe the PNOISE described there to calculate sampled noise is identical to what I called method 1 in my original post.
I agree that the two methods can only be equivalent when there is little or no frequency translation of noise. Since (I think) that is the situation I am simulating, my provisional conclusion is that in this case the two methods ARE equivalent. However I wish I could provide a rigorous argument to support (or refute!) it rather than relying on a small quantity of numerical data.
I will try to experiment with more/less non-linearity, more cascaded stages etc to see if I can isolate any systematic differences between the two methods.
Pete
vp1953
Reply #7 - Aug 27th, 2010, 4:24pm
Hi Pete,
Your meticulous analysis is interesting. If you do find out more about systematic differences between the two methods, please do post it here.
