Aug 4th, 2024, 7:11pm
About designing current mirror (Read 3901 times)
西楼
Aug 31st, 2010, 8:03am
Hello all,
 When I designed a current mirror,my design is hard to match what I expect.
 My design is expected to realize the function of a CCCS(current control current mirror).That is,when the input is I1,then two output would be 9I1,-9I1.
 In general, my design is as follows:
 I set mn=10, m31=90,m32=90
 The problem of my design  is dc current is very accurate,meanwhile ac response is very dissappointing.
 How to improve or solve my problem?
 Hope you can give your excellent suggestions,thanks a million. :)
AnalogDE
Re: About designing current mirror
Reply #1 - Aug 31st, 2010, 9:09am
Minimize L as much as possible (this reduces mirroring accuracy)
Minimize W as much as possible (Pay attention to headroom)
Avoid a 1:9 ratio and use multiple stages, i.e. 1:3:9
Reply #2 - Aug 31st, 2010, 10:49am
Trying to get bandwidth out of a current source?
Use a fixed current source and put a differential pair (current steering) above the current source and get you bandwidth there.
西楼
Reply #3 - Aug 31st, 2010, 8:02pm
Thank you for your kindness. You are right.As you said,W,L must be small as much as possible.When I change the W and L(randomly but of course be small),the ac response is much more better(simulation graph pasted below with R2/plus input signal;R0/plus,R1/plus  output signals).It is 10:10 ratio.
However,the input current is also pull down.I have to  tradeoff.Normally,input current can reach 20.8uA without any load.
The output signal,R1/plus,has a little ripple(the zoom in graph of R1/plus pasted below).
Besides,loose-electron,would you like to explain how to get the bandwidth of my design in detail? I can't quite follow you.Thank you again.
西楼
Reply #4 - Aug 31st, 2010, 8:19pm
The zoom in graph of R1/plus is pasted below.
Reply #5 - Sep 2nd, 2010, 8:06pm
You need to explain a lot more clearly the specifics of what you are trying to do.
THere are active amplifier methods of driving gate bias to create a wider BW structure, but then its not a "current source" it is a common gate amplifier.
A "current source" is generally a fixed bias structure.
