trashbox
The RTC circuit is attached and the measurement result shows 50% chip oscillation is failed: probing the PAD on failed chip can make it oscillate successfully.
The post/pre AC simulation shows the gain is about 24dB and the TRAN can also oscillate successfully without considering packaging(BGA) and I/O issues.
Is there any suggestion? Thanks!
