Aug 4th, 2024, 5:12pm
RTC oscillation failed (Read 1762 times)
trashbox
Sep 07th, 2010, 8:22pm
The RTC circuit is attached and the measurement result shows 50% chip oscillation is failed: probing the PAD on failed chip can make it oscillate successfully.
The post/pre AC simulation shows the gain is about 24dB and the TRAN can also oscillate successfully without considering packaging(BGA) and I/O issues.
Is there any suggestion? Thanks!
Re: RTC oscillation failed
Reply #1 - Sep 8th, 2010, 2:07am
Evaluate negative impedance of oscillator and compare it with effective resistance of crystal.
See http://www.yoketant.com.tw/yoketant/terms.htm
