Aug 16th, 2024, 7:55pm
why 50 ohms  impedance matching for low noise amplifier (Read 400 times)
saam
india
Sep 11th, 2010, 1:41am
why 50 ohms impedance matching in designing LNA,,why not 75 ohms..is there any specific reason for choosing that number???
 can anyone tel me
waiting for reply
saam
india
Re: why 50 ohms  impedance matching for low noise amplifier
Reply #2 - Sep 12th, 2010, 1:10am
Thank u.
I read that discussions but i am not clear .
I am new to rf   Sad   please can anyone clarify my basic Q'ns so that i can move in rf world
(1) matching impedance of LNA depends on the  type of  antenna we are using..is my statement is correct??? and 50ohms for which antenna???
(2)If there is no filter between antenna and LNA then what about the impedance matching for LNA  ???
(2) If there is a filter between antenna and LNA then what about the impedance matching for LNA and filter ???
(3)what is the effect of transmission line or co-axial cable on impedance matching???
Suryakumari
Reply #3 - Sep 12th, 2010, 1:28am
saam wrote on Sep 12th, 2010, 1:10am:
I don't think so.
With understanding only these easy questions, you can not still even touch a door of RF World.
Correct.
Impedance of conventional commercial product's antenna is 50ohm.
http://www.designers-guide.org/Forum/YaBB.pl?num=1245527790
(2) If there is no filter between antenna and LNA
You have to match input impedance of LNA to output impedance of antenna.
(2)(3) If there is a filter between antenna and LNA
then as matching for antenna-fliter and filter-LNA.
You have to care about termination's condition of filter.
So you have to apply it as matching for antenna-filter and filter-LNA.
(3)(4) what is the effect of transmission line or co-axial cable on impedance matching???
Consider a behavior of Γ in smith chart.
If line is perfectly lossless, Γ keeps a constant magnitude(that is a constant VSWR) and changes its phase.
« Last Edit: Sep 12th, 2010, 6:50am by pancho_hideboo »
saam
india
Reply #4 - Sep 12th, 2010, 2:07am
Thank u
loss of rf coaxial cabel is minimum around 50ohm characteristics impedance....can anyone tel me the reason??
suppose if v use 50 ohms co-axial cable for minimum loss then do v have to use the antenna having radiation resistance of 50 ohms  also
do v have to match the input impedance of LNA as 50 ohms???
If there is no feeder line between antenna  and LNA then as you said we have to match i/p impedance of LNA to the o/p impedance of antenna.
If If there is no feeder line between antenna  and LNA then what about the matching of LNa???
Thank u
suryakumari
Reply #5 - Sep 12th, 2010, 2:12am
saam wrote on Sep 12th, 2010, 2:07am:
Simply total loss of wall is minimum around Rc=50ohm in TEM-mode of coaxial-cable.
Rc value for true minimum loss is 76.7ohm not 50ohm.
But losses of them are almost same.
See any beginner text book on microwave engineering.
http://en.wikipedia.org/wiki/Coaxial_cable
also do v have to match the input impedance of LNA as 50 ohms???
Ideally yes.
« Last Edit: Sep 12th, 2010, 6:42am by pancho_hideboo »
saam
india
Reply #6 - Sep 12th, 2010, 2:47am
Rc value for true minimal loss is 76.7ohm not 50ohm.
then why don't they use 76.7 ohms ???
as you said conventional commercial antenna impedance is 50 ohms ..is it answer for my Q'n???
Thank u  so much  :)
Reply #7 - Sep 12th, 2010, 2:51am
saam wrote on Sep 12th, 2010, 2:47am:
Read http://www.designers-guide.org/Forum/YaBB.pl?num=1195659245/5#5 and http://en.wikipedia.org/wiki/Coaxial_cable surely.
Again from practical point of view, losses of Rc=50ohm and Rc=76.7ohm are almost same.
« Last Edit: Sep 12th, 2010, 4:03am by pancho_hideboo »
saam
india
Reply #8 - Sep 12th, 2010, 5:03am
Thank u Smiley
Reply #9 - Sep 14th, 2010, 6:14pm
50 (or for the fussy types, 52 ohms) is compromise between 77  ohms and 32 ohms
Best power handling is 30-32 ohms, and has been used for high power broadcast antenna systems in the past.
Best cable loss characteristic is at around 74 - 80 ohms and is commonly used in 75 ohm CATV systems to minimize system losses --
See:
http://www.microwaves101.com/encyclopedia/why50ohms.cfm
for a pretty good treatment of the subject.
Reply #10 - Sep 15th, 2010, 8:31am
loose-electron wrote on Sep 14th, 2010, 6:14pm:
I don't think so.
Input impedance of folded-dipole antenna is 300ohm.
This is a reason why Rc of parallel feeder is 300ohm.
If we feed this folded-dipole by single-ended, it is easy to use 1/4-balun.
So Rc of coaxial cable is chosen as 75ohm historically.
Reply #11 - Sep 15th, 2010, 1:48pm
Or use a 6:1 to go from 300 ohms of a folded dipole to
50 ohms.
Parallel wire (aka twin lead) comes in  300 and 200 ohm variations.
Go research the history of it.
pancho_hideboo wrote on Sep 15th, 2010, 8:31am:
I don't think so.
