Aug 4th, 2024, 11:21am
startup ciruit in BetaMultipler.... (Read 2222 times)
somisetty
Sep 14th, 2010, 12:20am
Hi All...
In the attachment,the startup circuit is used to avoid a condition "where the gate voltages of transistor M1,M2 become zero and M3,M4 become VDD and the circuit doesnt work".
Can anyone explain,why the gate voltages of M1,M2 go to zero and M3,M4 go to VDD?
Thanks a lot....
Garrett.Neaves
Analog Design
Engineer
United States
Re: startup ciruit in BetaMultipler....
Reply #1 - Sep 14th, 2010, 4:38am
The drain of M1 is connected to the gate of M1.  The impedance looking into the drain/gate of this connection is reduced compared to the impedance looking into the drain of a common source connection.  M3 is a common source connection.  The result is that there is a (much) lower impedance through M1 to ground than through M3 to Vdd thereby pulling the gate of M1,M2 to ground.
Use similar reasoning to understand why the gate of M4,M3 is pulled to Vdd.
Garrett Neaves
RobG
Bozeman, MT
Reply #2 - Sep 14th, 2010, 12:24pm
somisetty wrote on Sep 14th, 2010, 12:20am:
Hi All...
Thanks a lot....
That is just another way of saying that all transistors are off - which is a stable state that you don't want, hence the startup transistors.
