Jul 17th, 2024, 6:36pm
How can I get the position of poles and zeros of loop gain after stb analysis? (Read 1972 times)
frozenduck
Sep 16th, 2010, 8:33pm
I'm using stability analysis (Spectre) to get loop gain plot(magnitude, phase, Nyquist plot) to check stability.
When I want to check stability through Nyquist plot, the number of encirclement of (-1,0)  equals
P(RHP poles of loop gain also RHP poles of (1+loop gain)) - Z(RHP zeros of (1+loop gain )).
If there are RHP poles, the number of encirclement of (-1,0) will not be zero to make sure there are no RHP zeros(stable system).
"How can I get the position of poles and zeros of loop gain after stb analysis?"
I tried to recognize them from bode plot, but failed(it's too complicated).
Otherwise, if using pole-zero analysis in Spectre, the loop needs to be broken. As I know, it's not a good idea to do so in a closed loop system.(that's why we are using stb analysis)
Thanks.
Re: How can I get the position of poles and zeros of loop gain after stb analysis?
Reply #1 - Jan 2nd, 2011, 8:41am
You probably need to contact Cadence to request this. There are some existing enhancement requests asking for the poles and zeros of a specific loop - currently the pz analysis gives you the poles and zeros of the entire circuit, whereas stb gives you the loop gain of a specific loop (but does not decompose this into poles and zeros). To do so is not entirely straightforward.
Anyway, you should register your interest in developing a solution for this by requesting such an enhancement via Cadence Customer Support at http://support.cadence.com .
