Jul 17th, 2024, 12:31pm
Transient simulation of Verilog-A model - Explanation required (Read 2798 times)
kumar.g
Frankfurt, Germany
Sep 17th, 2010, 2:40am
Hallo All,
       I have simulated a D-latch using OFET. When running a transient simulation it gave me the following warnings.
"Matrix is singular (detected at `NQ')"
"Zero diagonal at net1 and net1"
           Then the simulation ended prematurely with convergence problem. Now I ran the simulation using a cmin of 1fF and then the zero diagonal warning disappeared and the circuit also converged. But the first warning is still there. I am giving a pulsed input to DIN but the output of the latch (Q and NQ) doesn't change. Is this error due to cmin or the first warning? I know that cmin is used at all floating nodes to avoid convergence problem. But does cmin affect the functionality of the circuit? I have attached the model(with parameters input file) and schematic. The inputs used are as follows.
DIN - pulse (-0.2 , -14 V); CLK - pulse (-0.2, -10.2V, freq = 100Hz) ,NCL- negated CLK
View Profile kumar.g write2rammy   IP Logged
Re:  Transient simulation of Verilog-A model - Explanation required
Reply #1 - Sep 22nd, 2010, 5:39am
Your code appears to set I(d,s) <+ 0 if (vds >= 0).
This seems completely wrong to me.  I don't know what an "OFET" is, but the way you've drawn your schematic leads me to believe vds>=0 is the "normal" way the device is connected, and thus both devices will be completely off, presenting no conduction path for the node inv_op of inv_sch.png.  Model writers will often put in a GMIN term to provide some minimal conductance.
kumar.g
Frankfurt, Germany
Reply #2 - Sep 22nd, 2010, 6:36am
Hello Coram,
        Thank you for your reply. Please note that the Vdd is -15V and the OFET is normally ON transistor. i.e it is ON even for Vgs = 0V... The output of INV switch between few mV and -14.75V.. The D terminal of load is -15V , S is few mV to -14.75V. So the Vds is not >= 0..  Similarly the S terminal of driver is 0V, D is mV to -14.75V. So teh Vds is not >= 0. Anyhow I will try to chk the schematic thoroughly..
Reply #3 - Sep 24th, 2010, 1:49pm
Well, OK, but still, if the simulator somehow gets to the point where it thinks vds > 0 (perhaps Newton's method ends up overshooting the origin), then your model provides no information about how to get back to a reasonable solution.
