Aug 4th, 2024, 3:10am
Question about temperature influence on circuit performance (Read 3422 times)
urian
Sep 18th, 2010, 6:34am
As we run simulation of a circuit,we see from spectre or else that with temperature increasing,the performance of the circuit degraded.Like the speed becomes slower.
But what the exact reason for this phenomenon?
I can imagine two reasons,one is that the mobility is decreasing while temperature increasing, the other is that the R has positive TC so its value becoming large and the RC constant has increased account for speed down.
I wonder whether one of my option is right?
And what about the influence on the gain with temperature?I think gm is aslo decreaed with mobility reduction,right?
Best regards
urian
raja.cedt
Re: Question about temperature influence on circuit performance
Reply #1 - Sep 18th, 2010, 7:19am
hi,
for most of the cases speed(i mean switching speed, VCO oscillation frequency) will increase due to Vt reduction. But i didn't understand why R will come into picture, for most of the cmos circuits transistor on resistance will matter. Coming to last point amplifier gain it depends what kind of architecture you are looking for...for example gm/gm load doesn't have much impact.
Thanks.
RobG
Bozeman, MT
Reply #2 - Sep 18th, 2010, 9:59am
You need to show your circuit if you want a meaningful answer.
But... in general analog circuits go faster with higher current and higher mobility (which both translate to higher gm).
Higher temperature decreases mobility and that would normally decreases speed. Similarly, if your circuit is biased with a positive TC resistor the speed would also tend to decrease as temp increases.
The general fix is to use a beta-multiplier bias circuit to keep the gm of the important devices constant over temperature by supplying a current that is roughly proportional to absolute temperature (aka PTAT).
rg
urian
Reply #3 - Sep 20th, 2010, 10:02pm
Thanks,RobG,and raja
All of the circuits I have simulated which used in a pipelined ADC show the same tendency. I think it all refers to the mobility since there are only transistor in my circuits.
urian
raja.cedt
Reply #4 - Sep 21st, 2010, 5:46am
hi,
please show me some results man..i didn't get any such type of result till now. how you are biasing you op amps in all stages..i guess you have to use at least one resister. isn't it?
Thanks.
urian
Reply #5 - Sep 21st, 2010, 8:32pm
hi,raja
I am doing comparator now,and havent move to MDAC yet.
and the comparator is like this.
