Aug 15th, 2024, 5:07am
Analysis Order Using Ocean (Read 2241 times)
Berti
Sep 21st, 2010, 12:25am
I would like to run a transient simulation (tran) followed by a stability analysis (stb). The stability (stb) analysis should use the final operating point of the transient analysis (using the previous operating point option).
This works fine from the Design Environment (GUI). If I start the simulation from an Ocean-Script, the stb analysis always runs first (before the transient analysis).
This is clearly a bug. Does anybody know a work-around?
Cheers
Re: Analysis Order Using Ocean
Reply #1 - Sep 21st, 2010, 6:43am
Berti,
  How about using actimes and acnames to run the stability analysis?
In your tran command add acnames=[stb] actimes=[final_time].
This functionality is intended to allow you to perform a specified small
signal analysis at a specified time. If you define multiple time points then
the analysis will be performed at each specified time point. BTW, you
won't need the independent stability analysis anymore.
Berti
Reply #2 - Sep 21st, 2010, 8:11am
Indeed, that works.
Thank you Sheldon!
