Surya,
This should have been posted to the circuit simulation since your question is tool related. You also refer to the tool that you seeking help with ADE, Spectre, ...
Have you connecting an ac current voltage source at the target node and forced an ac current, mag=1? Note: the other sources need to be disabled for this test.
Question for you, how would you calculate the conductance from the response?
Best Regards
