Berti,
How about using actimes and acnames to run the stability analysis? In your tran command add acnames=[stb] actimes=[final_time]. This functionality is intended to allow you to perform a specified small signal analysis at a specified time. If you define multiple time points then the analysis will be performed at each specified time point. BTW, you won't need the independent stability analysis anymore.
