Aug 4th, 2024, 1:16am
nPoly resistor (Read 1789 times)
newic
nPoly resistor
Sep 23rd, 2010, 6:24pm
Is there a need to put p-substrate taps around the npoly resistor? Does it really matter? The npoly is located on top of thin oxide. In my opinion, it does not really matter. Am i correct?
raja.cedt
Re: nPoly resistor
Reply #1 - Sep 23rd, 2010, 10:08pm
hi,
if you have 3rd terminal in resister then you have to do, even with out 3rd terminal also it is very good practice is to have some fixed potential for the substrate rather than having floating and it may coupled to some substrate noise also.
If you see PD SOI tech they will connect body to some fixed potential for this reason only
