carlgrace
What strategy for power down are you guys using for your analog circuits? Do you make sure every node is pulled high or low, or just the gates? For example, in an opamp, do you just kill it's bias circuit, or do you also make sure all the transistor drains are at one supply or the other (depending on if they are N or P devices)?
Carl
