Sep 20th, 2026, 12:23am
power-down strategy (Read 883 times)
carlgrace
Berkeley, CA
power-down strategy
Sep 24th, 2010, 3:02pm
What strategy for power down are you guys using for your analog circuits?  Do you make sure every node is pulled high or low, or just the gates?  For example, in an opamp, do you just kill it's bias circuit, or do you also make sure all the transistor drains are at one supply or the other (depending on if they are N or P devices)?
Carl
wave
Re: power-down strategy
Reply #1 - Sep 24th, 2010, 4:35pm
Carl - you have to be concerned with every node.  Generally turning off the biases will get you 80% there.  Then 20% will be remaining nodes floating that should be tied off.
The bug I've frequently seen is a high impedance node created by this strategy and overlooked as the simulator drove it one way (low or high); that shut down a follow-on node.  In face, that Hi-Z node can float anywhere causing the follow-on node to draw power.  Drains of comparators are a common place for this, since you asked about Gates.
Good luck,
Wave
raja.cedt
Reply #2 - Sep 25th, 2010, 4:30am
hi carl,
it depends on the type of application and till what extent you want power down safely. As wave told if you power down bias nodes means by connecting to vss or vdd you would be in a safe position. But it is always good practice is to pull down or pull up all possible nodes like tail node in diff pair and pass transistor gate node in the regulator. Don't put so many power downs....some times power down transistors from vdd as well as vss may create a low impedance path from vdd to vss (once this happen to me)
Thanks.
avlsi
singapore
Reply #3 - Sep 25th, 2010, 6:00am
I partially disagree with every node being pulled to high or low. Let us take the case of a regulator which gives 1.2 V output on the pad. In case if we want overdrive the whole chip with external supply, then the regulator must be disabled and the output must be at high impedance.
So it depends on each circuit. Defacto would be to leave of voltage sources like regulator outputs at high impedance so that we force them externally.
Winners never Quit,Quitters never Win
carlgrace
Berkeley, CA
Reply #4 - Sep 27th, 2010, 10:26am
Wave, Alvsi,
This was my thinking too.  If you leave a node floating, it might drift enough to turn on a device.  So what I have been doing is forcing every node that isn't overridden.  I was asking what other people did because all those switches become a bit of a pain in layout.
Thanks everyone,
Carl
RobG
Bozeman, MT
Reply #5 - Sep 27th, 2010, 3:10pm
In 18 years I've never felt it was necessary to tie down drains -- maybe if it was rad-hard or something special. A tri-state buffer floats the drains so I'm not sure what the problem would be.
But I definitely tie down the gates.
rg
