Jul 17th, 2024, 12:46pm
Tristate output of Analog value (Read 2844 times)
sand_dolphin2
Japan
Sep 27th, 2010, 12:22am
Hi there, i'm digital engineer.
Plz let me know about how 2 coding verilo-AMS.
Now i make test bench for checking inout I/O behavior.
For checking output behavior of I/O,
test bench which is connected to this I/O have to stop driving
like as tri state buffer of Logic  for checking I/O's output signal.
now my test bench was made by Verilog-D coding,
and DUT had 5V I/O (analog schematic design).
in this case, i should change digital 2 Analog converter
like here
module DAC_ams( Din , A5vout );
input  Din;
output A5vout;
electrical Din,A5vout;
real temp;
analog begin
@(cross(V(Din)-0.7,0));
  if(V(Din)>0.1) temp = 1;
  else temp=0;
V(A5vout) <+ 5*transition(temp,0,1n,1n);
when Logic test bench drive Hiz, this module stop driving too.
plz let me know how 2 correct this module for this aim ?
Roll Eyes
Re: Tristate output of Analog value
Reply #1 - Sep 27th, 2010, 1:26am
Sand Dolphin,
 It appears that your module always outputs a 5V
    If the V(Din) [rising edge]> 0.7 --> V( A5vout) = 5
    If the V(Din) [falling edge] < 0.7 --> V( A5vout) = 5
       since V(Din) > 0.1
 The V(Din) is only checked at the cross level. It seems like you need
to add two functions,
1) Method to define when to be in Hi-Z state
2) A HiZ output state
  I am not sure that you can use the output level of the previous
module to define a HiZ state since it is difficult to determine if the
the module output is transitioning or if it is in HiZ mode.
sand_dolphin2
Japan
Reply #2 - Sep 27th, 2010, 1:54am
sheldon wrote on Sep 27th, 2010, 1:26am:
Sand Dolphin,
       since V(Din) > 0.1
thx Sheldon,
i wana make correction only one point.
Din is Digital signal.
And we define L2E on other system 1.5v(D1),0v(D0) on tran 0ns.
thus, when Din goes to high, V(Din) reached 1.5v and
                Din goes to low, V(Din) reached 0v A.S.A.P.
this function model works fine now.
so how 2 add function Hiz-State by Analog solver(Verilog-AMS) ?
how about bellow way ?
I can make enable logic signal for driving or not. as ENABLE is set.
analog begin
  if((V(Din)>0.1) & ENABLE ) temp = 1;
  else if( ENABLE ) temp=0;
Sad
i know , i should try myself at first.
but i can't. cos i'm not so familiar w/t Analog tool Environment.
now , i'm making test bench on Analog tool Environment.
plz give me kindly help and advice.
« Last Edit: Sep 27th, 2010, 6:34pm by sand_dolphin2 »
