Amit_Analog wrote on Sep 29th, 2010, 11:15pm:3. When i close the file there is something else also appearing in the command promot like this:
sh: /net/chopin/cad/cadence2/ius61/tools/bin/ncvlog : can not execute binary file
This is probably the first thing to address. Perhaps icfb is getting a non-zero exit status (error) when trying to run ncvlog, and it thinks that means ncvlog couldn't parse the code, but it really means that it didn't run at all.
Is that path correct? Are you trying to run the wrong binary? (linux vs solaris? -- does anyone use solaris any more?) If you just type that path at the command prompt, what happens?
