Jul 17th, 2024, 12:35pm
Controlling Verilog-A Module Parameters Externally (Read 2863 times)
omar
Sep 29th, 2010, 11:20am
I'm working with verilog-a compact models in spectre. I am wondering if there is a  way to create a module such that I can change parameters in the module without opening the code.  For example, when we're working with the compact model of a transistor, it would be really helpful to change the width in each simulation without having to open the verilog-a code each time.
Amit_Analog
Re: Controlling Verilog-A Module Parameters Externally
Reply #1 - Sep 29th, 2010, 11:19pm
I think this one can be done. Edit the CDF from icfb for the symbol cell view you want to use. Add the parameters you want to parametrize.
This may be helpful:
http://www-scf.usc.edu/~ee577/cadence_tutorial4.html
Reply #2 - Sep 30th, 2010, 6:27am
Amit's suggestion is good, if you're using icfb.  If you're not, you need to tell us how you generate the spectre netlist.
omar
Reply #3 - Oct 1st, 2010, 12:24pm
Thanks for the suggestions.
Amit's approach seems to work.  I'm using icfb to get the netlists.
