Aug 17th, 2024, 1:43am
parameter sweep / operating point (Read 2500 times)
ontheverge
Sep 29th, 2010, 10:27pm
I'm trying to sweep the width of a MOSFET and check the corresponding changes of a few node voltages and seems the command SWEEP can not be used with .op
My question is, is it possible to do so without any .DC .AC or transient analysis?
thanks,
Stephen
ontheverge
Re: parameter sweep / operating point
Reply #1 - Sep 29th, 2010, 10:33pm
Sorry forgot to mention, I was using Avant! star HSpice
ontheverge
Reply #2 - Sep 30th, 2010, 12:36pm
pancho_hideboo wrote on Sep 30th, 2010, 5:08am:
Use ".alter" statement with ".op" statement.
.alter gives you only one set of new simulation data, while putting a bunch of .alter command will surely do, just wonder if easier ways exist
Reply #3 - Oct 4th, 2010, 2:14pm
ontheverge wrote on Sep 30th, 2010, 12:36pm:
Why not use .dc to sweep the parameter??
