Aug 16th, 2024, 6:48pm
Variable string handling (Read 3519 times)
Peter_R_Kroon
The Netherlands
Sep 30th, 2010, 3:03am
Because I wrote a generic module which checks signal events on a pin I want the pin name reported in a message generated by this module if the pin changes value.
For this moment I used the following definition for an input pin containing the name of a pin:
input [8*15:1] pin
However I want to make it generic because it is not known at front how many characters a pin name will be (I do not want to count this manually!) so I am looking to a construction where the number of pin name characters can be count and the outcome can be put on the position of the 15 in the example above.
Or if there is another simple way to import strings of the format "string" (including "")via an input pin into a module.
Inside the module it must be possible to check if the received string has a certain contents!
Peter
Re: Variable string handling
Reply #1 - Sep 30th, 2010, 6:26am
How are you setting the value of that input pin -- do you have another module that sets it?
I also can't think of a way that you could possibly use that input to do anything useful.
I could imagine using a "string parameter" in VAMS:
 parameter string pin_to_check = "NONE";
 if (pin_to_check == "INA") begin
   // do something
 end else if (pin_to_check == "INB") begin
   // do something
 end else
   $strobe(" pin_to_check=%s is not a valid pin!", pin_to_check);
But in this case, you have to have a set of fixed strings to check against.  AMS allows only limited string operations, one of which is test-equal (==).
Peter_R_Kroon
The Netherlands
Reply #2 - Sep 30th, 2010, 11:31pm
Geoffrey,
Unfortunately I can not use the phrase "parameter string pin_to_check = "NONE"" in my code, I get then an error that a semicolon is expected on the position of the word "string".
I can try to define the parameter definition without the string word supplement and see if I can use the parameter in equations.
FYI: I am using the cadence toolsuite for compiling + simulation.
Reply #3 - Oct 4th, 2010, 2:18pm
Search this forum for "string parameter" -- I'm pretty sure someone posted something about being able to use them, but there was a trick.
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Reply #4 - Nov 17th, 2010, 7:54am
For support of string parameters you will need to use a recent version of Cadence MMSIM stream. In Spectre 7.2 it is supported.
Marq
Peter_R_Kroon
The Netherlands
Reply #5 - Nov 18th, 2010, 12:35am
Marq,
I found sofar a satisfactory solution for my problem so my probem is solved for the moment. I used as a compromise a name parameter added to the generic module. The parameter name is used now only for messages and not anymore for comparison so in that way it is kept simple.
This thread can be closed now  :)
