Aug 2nd, 2024, 7:17pm
on 0.13um tech. (Read 1083 times)
ontheverge
on 0.13um tech.
Oct 05th, 2010, 4:50pm
I was designing an folded cascode op-amp in 0.13um technology, the single stage gain requirement dictates that channel length to be larger than 0.35um (with specific circuit architecture), if the way i designed it was right, does that mean the technology was wasted?
thanks,
Steve
AnalogDE
Re: on 0.13um tech.
Reply #1 - Oct 6th, 2010, 9:00am
I'd recommend sizing the cascodes using minimum channel length.
raja.cedt
Re: on 0.13um tech.
Reply #2 - Oct 6th, 2010, 7:09pm
hi steve,
what do you mean by wasted, mainly these process nodes are highly digitally biased..so you don't get good gds, in fact there are people who design analog design circuits with 1u channel length also. so what i my suggestion is try to use min-length devices wherever possible like cascode devices.
Thanks.
Re: on 0.13um tech.
Reply #3 - Oct 6th, 2010, 7:47pm
Hi Steve,
There must be more specs than the DC gain. So your choice of the channel length is a compromise of all specifications. Does the current channel length result in a good balance between power, speed, gain, area, mismatch, noise, and so on? If the answer is YES, it's fine. Anyway, the deep sub-micron technology is optimized for digital design, not for analog.
Yawei
love_analog
Re: on 0.13um tech.
Reply #4 - Oct 11th, 2010, 6:10am
This is not wasted. What it means is that you are using a larger Length device to get higher Rout.
loveanalog.blogspot.com
The Power of Analog
Lex
Eindhoven, Holland
Re: on 0.13um tech.
Reply #5 - Oct 13th, 2010, 7:54am
If you are using the 3.3V devices, a gate length of 0.35 um is quite minimal.
