Aug 16th, 2024, 7:36pm
cascode device sizing (Read 9146 times)
saam
india
Oct 06th, 2010, 5:01am
Device Sizing in Cascode Stage:
The cascoded stage provides a reasonably low (about 3
dB) noise figure. One relationship reducing NF should be
mentioned. If the body effect is absent then the width of the
cascoding transistor M2, should be chosen three times less
(this ratio may slightly vary during simulations) than that of
the input transistor M1. It is contrary to the common practice
to use the devices of the same width and may be used when the
transistors are in separate wells.
          Can anyone explain why it is so?
Thank U
saam
raja.cedt
Re: cascode device sizing
Reply #1 - Oct 6th, 2010, 5:54am
hi,
what do you mean by common practice? i have never used same width for cascode, its lot less  compared to main device..
Thanks.
rfcooltools.com
Reply #2 - Oct 6th, 2010, 9:30pm
Saam,
The main reason for the cascode is to increase output resistance, but to increase ouput resistance while decreasing output capacitance is a bonus not to be passed up. Im with raja use the smallest device you  can get away with.
http://rfcooltools.com
anil reddy
India
Reply #3 - Oct 7th, 2010, 8:54am
hi,
  as mentioned above, the main use of cascode structures is that it increases the gain by increasing the output resistance and to isolate the input and output, particularly in RF circuits. i think there is no reason why you should use the same device width, in fact, as raja mentioned it can be a lot lesser than the main device and as it usually is. the device width depends on it's gate bias. if you connect the gate to supply then the width be a lot less. we don't need to worry about the noise of the cascode device because it doesn't add to the output.
thank you..
RFICDUDE
Reply #4 - Oct 7th, 2010, 6:07pm
Hmm, I find these comments interesting because of the following reasons:
1. I was raised to believe that an important benefit of cascoding is extending the high frequency bandwidth by reducing the Miller Effect multiplication of Cgd referred to the input resulting from the inverted voltage gain between the drain and gate. For LNAs the improved high frequency gain certainly has some benefit for input referred noise and also some impact on the input impedance.
2. Decreasing the width of the common gate device raises the load impedance at the interface between the CS and CG stage, so the voltage swing is higher at this node (as mentioned in #1). I would think, but I don't know for sure, that this would have some impact on linearity.
3. Vgs for the CG stage will increase due to the decreased width (increased current density since the current is set by the CS device), so the gate voltage should be higher to maintain the same Vds bias for the CS stage. The higher gate voltage may result in lower P-1dB gain compression point of the LNA.
I apologize for not answering the original question regarding the 3:1 width ratio. I would have to do a little analysis to figure out what the benefit is.
vp1953
Reply #5 - Oct 8th, 2010, 4:59pm
HI RFICDUDE,
Agree with all your other points.
Normally in many designs, the gate of the CG stage is connected to VDD and there is no special biasing scheme for this node. Now I would have thought that higher the gate voltage, it would result in more linearity. One line of thought (and something that could be faulty) is that lower the gate voltage, lower will be the permissible voltage swing at the drain of the CS stage and the incoming signal would start getting clipped/compressed sooner.
Taking this line of thought to its extreme, where the gate voltage on the CG stage is so low that the CS stage is essentially operating in the linear regime. Now in this case, linearity is pretty good but gain has come down substantially.
I think whether linearity is improved or worsens depends on a lot of factors,
RFICDUDE
Reply #6 - Oct 9th, 2010, 5:04am
Yes, higher CG gate voltage improves the linearity of the CS stage; although any headroom above what is needed for the gain to the CG-CS interface is pretty much wasted. Keep in mind the voltage gain to this interface should be small (proportional to gm_cs/gm_cg).
However, making the CG device narrower will increase its Vgs for the same current, so Vs has to decrease (since Vg=Vdd) which lowers Vds on the CS device.
Also, setting Vg=Vdd for the CG device means the peak output swing is limited to Vt (assuming an inductor load) since Vd can only drop below Vg by Vt before the CG device falls into triode. This can also have a limiting effect on the input referred linearity.
rfcooltools.com
Reply #7 - Oct 9th, 2010, 10:00am
Probably I should have put more thought into what I was writing
by small as possible :
1.  start by reducing the length
2.  then reduce width and repeat 1. until the desired tradeoffs are met.
Deep submicron MOS requires more thought then this
saam
india
Reply #8 - Oct 11th, 2010, 6:19am
Hello
      Thank You for the valuable information provided..
      From the information as simply i understood that , cascode device is mainly used to avoid miller effect and to improve the gain...also in this if we choose proper cascode device sizing we can obtain the required bandwidth.
      Currently i am designing this resistive feedback LNA(the circuit which i have attached ) for 2-6GHz frequency range. But this circuit is from 2-11.2GHz wide band.
     So for my design i used series LC circuit parallel with active inductor...so i got gain only for 2-6GHz, but problem is that i am getting input matching only for 3-6GHz.
     I am not able to find which parameter i have to vary to move S11 upto 2GHz.(towards left)...with gain tradeoff.
     Can anyone help me....
Thank You
Saam
rfmagic
Reply #9 - Oct 11th, 2010, 7:56am
I dont see the circuit that you attached. can you attach it again?
saam
india
Reply #10 - Oct 11th, 2010, 10:23pm
I am attaching the designed circuit and waveforms for S21 and S11..please find
saam
india
Reply #11 - Oct 11th, 2010, 10:24pm
I am attaching the designed circuit...
