lunren wrote on Oct 11th, 2010, 12:47pm:Thanks for reminding me. Almost forget how to use SpectreRF.
You are still misunderstanding PSS and QPSS of Cadence Spectre.lunren wrote on Oct 11th, 2010, 12:47pm:PSS is used for one beat frequency
and QPSS is used for more than one beat frequencies.
Wrong.
There is no concept of "
beat frequency" in both PSS and QPSS of Cadence Spectre.
See the followings.
http://www.designers-guide.org/Forum/YaBB.pl?num=1232036048/4#4http://www.designers-guide.org/Forum/YaBB.pl?num=1268969030/7#7lunren wrote on Oct 11th, 2010, 12:47pm:pancho_hideboo wrote on Oct 8th, 2010, 10:55pm:lunren wrote on Oct 8th, 2010, 12:41pm:qpnoise is that QPSS only works for sinusoidal tone.
Very completely wrong.
This is what I get from setting up the QPSS.
The large signal can be pulse waveform, other medium signal must be sinusoidal waveform.
Wrong.
Other medium signals also can be pulse waveform.
However from practical point of view, if you use pulse wave as medium signal,
convergence of QPSS of Cadence Spectre is very very very bad.
This is very true especially for
Shooting-Newton-QPSS.
lunren wrote on Oct 11th, 2010, 12:47pm:I know for Pnosie(source), the frequency range should be from 0 to inf
and for Pnoise(timedomain), the frequency range should be from 0 to beat_frequence/2.
I am using 12.5Mhz as the upper analysis frequency for Pnoise(timedomain).
Did you describe you are invoking "Pnoise(timedomain)" in your post ?
And it has to be "fundamental_frequency/2" not "beat_frequency/2".The followings are general notes for you.
- Always describe correct tool's name and vendor's name which you use as tool or simulator.
- Don't do multiple posts which are same content.
- Don't request source code or behavioral model without any efforts.
- There are many simulators which have analyses called as PSS, PAC and Pnoise.
Describe in detail and correctly with using correct terminologies.- Warnigns are different from Errors.
- ADS is not name of simulator.
- There is no tool which name is Cadence.
- Don't use Direct Plot of Cadence ADE blindly without knowing definition.
- All gains in Direct Plot of Cadence ADE are "right", "true" and "practical" voltage gain.
- Don't mix up Simulation with Post Processing. They are completely different phase.
- MATLAB are different from Simulink.
- Learn measurements using actual instruments. Not "EDA Tool Play
