Aug 31st, 2024, 6:21pm
some questions about Type 3 Compensation for dc-dc (Read 9856 times)
waseda-rfic
Oct 17th, 2010, 5:51am
the Type 3 Conventional Operational Amplifier Compensation introduce 3 poles and 2 two zreos. it uses 2 pole to Compensate two zeros in dc-dc and uses 2 zeros to Compensate poles in dc-dc .
I want to ask two questions:
1. when design the Compensation  circuit , the operational amplifier has its own poles and zeros besides the 3 poles and 2 two zreos, how to do with the poles and zeros of the operational amplifier.
2. there are two  pole-at-zero when the dc-dc is Compensated. the  pole-at-zeros have bad effect on transient response of the loop. whether the two  pole-at-zero have bad effect on transient response of the loop.?
raja.cedt
Re: some questions about Type 3 Compensation for dc-dc
Reply #1 - Oct 21st, 2010, 2:54am
hi,
whatever be the poles and zero location of your op-amp if they are well beyond UGB then fine.
Thanks.
waseda-rfic
Reply #2 - Nov 1st, 2010, 6:35pm
raja.cedt wrote on Oct 21st, 2010, 2:54am:
hi,
Thanks.
Thanks! but the main pole of the OPA is usually several hundred Hz, so it is hard to beyond the poles and zero location I need in the dc-dc
Lex
Eindhoven, Holland
Reply #3 - Dec 7th, 2010, 11:54pm
from a quick google-search this pops up:
http://designtools.analog.com/dt/stability/stability.html
« Last Edit: Dec 8th, 2010, 6:54pm by Forum Administrator »
