Jul 31st, 2024, 11:15pm
Maximize ICMR (Read 3030 times)
extremis
Maximize ICMR
Oct 19th, 2010, 7:36am
I am designing an OPAMP with 0.6μm technology (Vtp=-0.9V, Vtn=0.7V) and i have a specification of ICMR=0.5-2.5V to meet. The power supply is 3V (single). I have considered the clasic 2 stage OPAMP with Miller compensation, the cascode and the folded cascode OPAMP, but i don't see how the ICMR requirement could be satisfied.
The folded cascode OPAMP seems to meet either the upper or the lower specification depending whether it has a NMOS or PMOS input differential pair, but not both. Could anyone suggest a simple topology that could meet the ICMR specification?
Thanks in advance.
AnalogDE
Re: Maximize ICMR
Reply #1 - Oct 19th, 2010, 9:29am
I think you need an input stage that contains both N and P diff pairs.  Search for "rail-to-rail" OTAs/op-amps.
extremis
Re: Maximize ICMR
Reply #2 - Oct 22nd, 2010, 2:56am
Thanks for the advice. I have found some rail to rail topologies, but they are too complicated and might even not satisfy other requirements. I was wondering if there is some kind of trick to increase ICMR using a simple topology.
Dan Clement
Salt Lake City, Utah, USA
Re: Maximize ICMR
Reply #3 - Oct 23rd, 2010, 1:03pm
Level shifters...  Like resistor dividers or source followers.
Rail to rail amps can be a real pain because now you have two input stages to lead to distortion, offset, noise, etc...
Good luck.
extremis
Re: Maximize ICMR
Reply #4 - Nov 23rd, 2010, 8:14am
Dan, i tried both approaches: source followers work just fine until Vcm~0.8V but after that the gain is lowered and resistor dividers seem to degrade performance, especially slew rate. I guess it has something to do with input capacitances but still i cannot find any way around it.
