supermoment
How do I determine the 50ohm buffer current? The current can be huge different for ac couple case and without ac couple case. For the case of 2VDD and 500mV ac swing:
AC couple case: 500mV/50ohm=10mA (AC signal only) without AC couple case: 2V/50ohm=40mA!! (DC + AC signal)
Just wanna know which case should be normally used for high-speed digital signal in gigahertz range? I think the without AC couple case, the current is too large and ac couple case should be used. Pls commend.
