AnalogDE
I'm doing some research on current reference schemes. I've seen the following two schemes: Both utilize a BGR/VREF to generate a gate bias
1. NMOS biased at ZTC (zero-tempco point), where mobility and vth variation cancel each other.
2. NMOS in series with opposite tempco resistor -- NMOS has positive tempco resistance balanced with negative tempco resistor.
What are the pros/cons of the two schemes? Any pointers to references/papers appreciated.
