Aug 1st, 2024, 9:13pm
CMOS current reference schemes (Read 44 times)
AnalogDE
Oct 25th, 2010, 11:41am
I'm doing some research on current reference schemes.  I've seen the following two schemes:  Both utilize a BGR/VREF to generate a gate bias
1.  NMOS biased at ZTC (zero-tempco point), where mobility and vth variation cancel each other.
2.  NMOS in series with opposite tempco resistor -- NMOS has positive tempco resistance balanced with negative tempco resistor.
What are the pros/cons of the two schemes?  Any pointers to references/papers appreciated.
