Jul 17th, 2024, 1:28pm
parallel QVCO issue (Read 290 times)
ieok
parallel QVCO issue
Oct 27th, 2010, 3:18am
How to make sure QVCO output has accurate in-phase & quadrature phase clock?  I use the parallel type QVCO  (identical osc).
In my testbench A, the qvco works properly but when move to testbench B, it did not wok properly like:  no longer 90o shift, different swing amplitude. It looks like it depends on initial voltage of the oscillator.
thank you in advance.
