Jul 17th, 2024, 1:17pm
stability issue..... (Read 2148 times)
saam
india
Oct 27th, 2010, 6:10am
         Capacitor C also serves for ensuring the stability of the circuit. Since the open-loop transfer function has two poles very close to each other, introducing a dominant pole at node 2 improves stability.
         Can anyone explain why? (i am attaching the circuit)
Thank U
saam
jayce3390
Re: stability issue.....
Reply #1 - Dec 2nd, 2010, 8:07am
This is real part of poles which is important, not the fact that they are close to each other...
You need poles with a negative real part to ensure stability.
Frank Wiedmann
Munich, Germany
Reply #2 - Dec 3rd, 2010, 12:58am
See http://web.engr.oregonstate.edu/~karti/ece422/lec11_16_10.pdf, especially the slides entitled "Adding a Dominant Pole".
