Jul 18th, 2024, 5:18am
ADE netlist and run: can't find hdl.var (Read 735 times)
RF2RTLitsAllGood
Oct 30th, 2010, 4:41am
To anyone who can help,
I am trying to follow the Cadence tutorial: AMS in Virtuoso.
I am using IC611 and IUS82.
When I try running the simulation the simulator quits. When I view the NCVLOG log error it complains about not finding the hdl.var required for setting up the verilog simulator. I have place an hdl.var file in the directory I invoked virtuoso from and in my home directory (both included in the setup.loc file) I have also defined the path for this file in CIW's ams compiler options. This path is then defined in the ams.env file in the working directory. I have found that further down in my working directory, where the spectre simulation files are located, there is another ams.env file which has information relevant to the simulation I am trying to run. I have tried adding the hdl.var path to this ams.env file. But when I run the simulator this file is recreated, thus over writing my changes.
Does anyone know where I can specify the path to hdl.var in ADE to run AMS simulations with spectre? Or does anyone know where I can put the hdl.var file so the tools can find it?
If you need anymore information please let me know.
Thank you,
Brian
RF2RTLitsAllGood
jerome_ams
Re: ADE netlist and run: can't find hdl.var
Reply #1 - Nov 8th, 2010, 7:45am
U could try to define your hdl.var from the ADE GUI itself, under Simulation-> Options -> Compiler -> hdl.var
Hope it helps,
jerome
RF2RTLitsAllGood
Reply #2 - Nov 14th, 2010, 4:45am
Thank you that helped.
