Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 1
st
, 2024, 5:22am
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› two stg OTA
Previous topic
Next topic
two stg OTA (Read 3889 times)
ontheverge
two stg OTA
Nov 01
st
, 2010, 1:47am
I noticed that in miller-compensated two stage OTA, if the first stage is PMOS driven, the output stg is NMOS and vice versa, is there a special reason for that?
thanks,
Steve
IP Logged
raja.cedt
Re: two stg OTA
Reply #1 -
Nov 1
st
, 2010, 2:09am
hi,
1.common mode voltage of the 1st stage o/p can easily drive 2nd stage with out any level shifting.
2.Supply rejection will be good.
Thanks.
IP Logged
ontheverge
Re: two stg OTA
Reply #2 -
Nov 1
st
, 2010, 5:39pm
Hi Raja,
thanks for the reply, can u elaborate a little bit on supply rejection?
thanks,
Steve
IP Logged
raja.cedt
Re: two stg OTA
Reply #3 -
Nov 1
st
, 2010, 7:58pm
hi,
Assume you have nmos input diff pair in the first stage and pmos input 2nd stage, so due to pmos diode connected load at the first stage entire supply noise will come to output, so if 2nd stage is pmos then pmos gate will change by same amount of supply noise and at the same time source will be changed by same amount due to VDD connection. hence you would not see any change in 2nd stage output.
Thanks.
IP Logged
aamar
Re: two stg OTA
Reply #4 -
Nov 2
nd
, 2010, 9:40am
There are other two advantages which are
1. for the highest gain of the second stage, the vin (common mode as raja mentioned) for the second stage input transistor should be biased near the vth or vdd-vth in case of nmos and pmos respectively, which is then best implemented using the opposite type transistor from that used in the input differential pair.
2. The load of the second stage is a mirror from the tail current of the first stage and therefore no need for an additional bias voltage.
Best regards,
aamar
Last Edit: Nov 3
rd
, 2010, 12:56am by aamar
IP Logged
HdrChopper
Re: two stg OTA
Reply #5 -
Nov 15
th
, 2010, 6:28pm
one advantage more...
the second stage being the same type of the first stage active load allows for perfect balance of voltages if properly sized, thus systematic input referred offset can be minimized
Best
Tosei
Keep it simple
IP Logged
raja.cedt
Re: two stg OTA
Reply #6 -
Nov 15
th
, 2010, 8:31pm
hi chopper,
if i am correct you are talking about sharing bias between both stages rite....
Thanks.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
