Hi Rfcooltools,
Quote:This is problematic for two reasons first the signal sourced to you LNA will radiate at some frequency which may be at the desired or even at a harmonic and the FCC will deliver the cease and desist notice to the product.
Are you referring to re-radiation of the incoming signal (the fact that some of the incident signal is dissipated in the antenna source impedance, which shows up as re-radiation).
If it is just reradiation (even if the reradiation is frequency sensitive), it would not be considered an "intentional radiator" and hence no need to be certified under FCC Part 15 rules. Eg of such systems, passive RFID tags that backscatter the incoming radiation (at datarates from 40kbits to 600kbits) do not need FCC certification.
Could you elaborate a little more on the issue with the antenna - I am keen to know more about this as this is something that i am looking into currently.
