rho
Belgium
I have a sub-cell layout with separated bulk and GND routings. So the source and bulk for all NMOS is routed separated and both lines have different netnames. Now there is a p-well that is conneted to the GND line and Assura sees that as a soft connect between bulk and GND (which in fact it is) and this generates errors. Is there a way to connect these two nets just for LVS checks and not in the layout? Is there a function where I can connect the GND-net with the bulk-net? I know the "joinablenet" function but this only works for nets with the same name.
Thanks for your help!
