Aug 16th, 2024, 7:48pm
Modulated output power versus single tone (Read 1951 times)
archmage
Nov 13th, 2010, 2:25am
I'm just wondering if the single tone measured gain is identical with the gain measured with a modulated signal.
Let's say I have a PA that has G = 25dB and I drive it with Pin = 0 dBm - single tone at 2GHz. If I then drive it with equivalent WCDMA modulated input signal (Pin = 0 dBm) will I get the same Pout? (assuming the PA is far away from being saturated)
RFICDUDE
Re: Modulated output power versus single tone
Reply #1 - Nov 14th, 2010, 5:29pm
Yes, the power is the same so long as the gain is linear.
rfmagic
Reply #2 - Nov 15th, 2010, 1:23am
The integrated power will be the same in both cases.
the gain will be the same no matter what the integrated band is.
