Jul 17th, 2024, 5:24pm
TRAN+STB  or  PSS+PSTB ? (Read 3380 times)
the_wavefunction
Nov 15th, 2010, 7:56am
Circuit:
A VCO + simple 2-stage opamp that feeds the VCO comprise my entire circuit.  Also, a feedback path is taken from the VCO back to the opamp.
Question:
Now, which method is the appropriate one to find out the stability of the opamp loop using iprobe component  -  tran+stb  or  pss+pstb ?
Is it tran+stb because its an opamp loop? or is it pss+pstb because there is an oscillator?
Since I'm unsure, I curiously tried simulating with both methods.
The loop gain plots seem totally different and so do the corresponding gain and phase margins!  For e.g: the loop gain magnitude for pss+pstb almost always starts from close to 0 dB and rises midway around, irrespective of the opamp open loop gain.
Could anyone kindly suggest the right analysis that suits this task?
the_wavefunction
Re: TRAN+STB  or  PSS+PSTB ?
Reply #1 - Nov 15th, 2010, 9:27am
Thank you pancho_hideboo.
Let me take a humble bow for your enlightening and thought-provoking suggestions!
The circuit simulator is Spectre 7.1.1 - 32 bit, and the tech lib is 0.18um TSMC.
And I sincerely hope, the names 'VCO' and 'opamp' stay the same immaterial of Cadence or Synopsys or ADS!  Kindly correct me if I'm wrong.
Thanks once again Smiley
Reply #2 - Nov 15th, 2010, 9:29am
You would use pss+pstb because the effective operating point is periodically varying. With tran+stb you effectively freeze the oscillator at a certain point in its limit cycle, which would give the wrong result.
the_wavefunction
Reply #3 - Nov 15th, 2010, 10:31am
Thanks a lot for your inputs, Ken!
I'll proceed that way.
