Aug 17th, 2024, 11:18pm
linearity - capacitor matching requirement (Read 2800 times)
ontheverge
Nov 21st, 2010, 9:01pm
can anyone explain how to relate the linearity requirement to capacitor mismatch requirement (under certain assumptions if necessary) in pipelined ADC? for example, what does 12b ADC translate to capacitor matching requirement deltaC/C ?
thanks,
Steve
carlgrace
Berkeley, CA
Re: linearity - capacitor matching requirement
Reply #1 - Nov 22nd, 2010, 10:05pm
Steve,
Most books and theses that cover Pipelined ADC design will help you here.  In particular, read the PhD theses of Abo and Chien, they are classics and go through the derivations of the different components.
To answer your question, you can write out the gain equation for a Pipeline stage and see that, given high op-amp open-loop gain, the caps need to match to at least 1/2 LSB at the accuracy of the resolution remaining after the first stage (this statement is valid in multibit or single-bit first stages).  So, if you have have a 12b ADC with a 1.5b first stage, the deltaC/C needs to be less than 1/2 times 11bit-accuracy, or 1 part in 4096.  (You also have to multiply this by one over the feedback factor, see the theses I mentioned for the explanation).
If caps of this accuracy slow down the stage or make it use too much power you can use a mulit-bit first stage or look into calibration.  The place to start for that subject is the paper by Karanicolas.
Carl
ontheverge
Reply #2 - Nov 23rd, 2010, 1:36pm
problem solved, right on P94 of the thesis u mentioned, thank you, Carl
