Jul 18th, 2024, 7:26am
AMS +elaborate+error (Read 13533 times)
mustangyhz
china
Nov 22nd, 2010, 3:47am
ncelab: *W,CUNOUN: Cannot find any unit under chrt18base.RFNMOS_1P8:spectre in the design libraries.
ncelab: *E,CUCFUN: instance 'NM0' of the unit 'RFNMOS_1P8' is unresolved in 'pllmml.dts:schematic'.
how can I solve this?
one solution:
Because the AMS simulation is different from spectre, so we must use the CIW-Conversion Tool Box-AMS simInfo form Spectre to creat the simulation information of the PDK.
After doing this, my simulation still can not run. why?
help!!!
mustangyhz
View Profile mustangyhz 3241568   IP Logged
mustangyhz
china
Re: AMS +elaborate+error
Reply #1 - Nov 22nd, 2010, 5:24am
liberary name:     the library name of PDK or my design library?
process allcells in the library:                        select or not?
process only cells with the following view:      select or not?
if AMS simulation information exists:
only copy termmapping field                          select or not?
overwrite ams simulation information              select or not?
mark a cell as a primitive:
if any of modelmame/model/modelname are found   select or not?
if the cell has a spectre view                                    select or not?
mustangyhz
Reply #2 - Nov 22nd, 2010, 8:51pm
Mustangyhz,
  Maybe you should spend some time working with your local support.
It seems like you need someone to help you through setup and
simulation process. BTW, unless you are using a very old version of
AMS Designer you should only need Spectre simulation information
and you should not need to create an ams siminfo section.
mustangyhz
china
Reply #3 - Nov 22nd, 2010, 10:21pm
I have installed ic5141 user6, ius8.2,mmsim610. Are they too old?
mustangyhz
mustangyhz
china
Reply #4 - Nov 23rd, 2010, 12:27am
I have changed the pdk to tsmc.
I have got the siminfo->ams.
I still got these error:
ncelab: *N,SFEDPL: Deploying new SFE in analog engine.
ncelab: *W,CUNOUN: Cannot find any unit under tsmc18rf.rm1:spectre in the design libraries.
ncelab: *E,CUCFUN: instance 'R0' of the unit 'rm1' is unresolved in 'pllmmlverilogtsmc.plltop:schematic'.
why?
mustangyhz
jerome_ams
Reply #5 - Nov 24th, 2010, 9:38am
How are you defining the model (Cadence view) you want to simulate for R0?
What kind of component is R0? A spectre resistor?
Cheers,
Jerome
mustangyhz
china
Reply #6 - Nov 24th, 2010, 4:09pm
jerome_ams
Cadence view name: spectre
Rm1 is a spectre resistor?
thanks
mustangyhz
mustangyhz
jerome_ams
Reply #7 - Nov 29th, 2010, 8:40am
I usually give "symbol" view in the hierarchy editor for components of the analogLib.
What occurs if you do a right mouse click on the spectre view in your hierarchy editor and click then on "compile"?
mustangyhz
china
Reply #8 - Nov 29th, 2010, 5:14pm
components of the analogLib is ok!
mustangyhz
bernd
Munich/Germany
Reply #9 - Nov 30th, 2010, 2:42am
I don't know which tools versions you were using
and if you use the ADE environment as AMS interface,
but if so you may give the OSS-based netlisting a chance
Simulation -> Netlist and Run Options
OSS-based netlist with irun
* bernd
Just another lonesome cad guy
jerome_ams
Reply #10 - Dec 1st, 2010, 6:06am
yes, u could try a Netlist All (default: incremental), Compile All (default: incremental) from the AMS>Netlist and Run>Run Options Menu in Hierachy Editor.
It might it that the model u want to simulate is not "pre-compiled" like the components in the analogLib... U should be able to compile it, doing what Bernd proposed.
If it complains that the library containing your spectre model is read only, and thus thaht it can not compile, then Assign a TMP for this Lib
Hope it helps
jerome
Reply #11 - Jan 2nd, 2011, 10:09pm
Most likely you've just not specified the path to the spectre models for the transistors. If using ADE this is under Simulation->Model Libraries (just as it is for spectre). There's a similar menu if using the AMS Plugin in the hierarchy editor.
