jerome_ams
yes, u could try a Netlist All (default: incremental), Compile All (default: incremental) from the AMS>Netlist and Run>Run Options Menu in Hierachy Editor.
It might it that the model u want to simulate is not "pre-compiled" like the components in the analogLib... U should be able to compile it, doing what Bernd proposed. If it complains that the library containing your spectre model is read only, and thus thaht it can not compile, then Assign a TMP for this Lib
Hope it helps
jerome
