Sep 17th, 2024, 1:05am
SFDR and Reference Level of Spectrum Analyzer (Read 12312 times)
Nov 24th, 2010, 10:05pm
Hi Guys,
When I measured a sine wave with spectrum analyzer. I am curious that the reference level impacts the harmonics. For ref level = 0 dBm, SFDR ≈ 72 dBc. For ref level = 10 dBm, SFDR ≈ 81 dB. I thought the reference level is used to adjust the display only. I am reading a few documents of Agilent about spectrum analyzer. However, I have not find the answer until now. Would you please comments this phenomina?
Yawei
Re: SFDR and Reference Level of Spectrum Analyzer
Reply #1 - Nov 24th, 2010, 10:06pm
Reference Level = 0 dBm
Reply #2 - Nov 24th, 2010, 10:07pm
Reference Level = 10 dBm
currant
Reply #3 - Nov 25th, 2010, 12:22am
Hi,  ywguo.
I think answer is simple. You overload internal circuits of spectrum analyzer (SA). As it can sees in your pictures, when You modify  refLevel - value of internal attenuator also modify, and input signal attenuate before it come on SA's internal circuits. This is bad for noise (SNR) measurment, but good for HD measurment.
Best regards.
Reply #4 - Nov 25th, 2010, 7:42pm
Hi Currant,
I have not noticed the change of ATTN.
Yawei
« Last Edit: Nov 26th, 2010, 2:30am by ywguo »
rfidea
Europe
Reply #5 - Dec 31st, 2010, 2:04am
I agree with Currant. Changing the reflvl will change the internal signal level in the analyser, it does not only change the display. The spectrum analyser is a radio receiver!
/ssahl
